It is currently Sat Aug 09, 2025 7:00 am
 Post subject: Neck Blank Size & Cut
PostPosted: Thu Feb 02, 2017 4:26 pm
Last Name: Simmons
State: Ohio
So, I'm starting my first acoustic build after completing two electrics.
I've got a 19mm thick, rift sawn mahogany board that I'd like to use for a few acoustic necks.
Is that too thin to use? I also know that quarter sawn is ideal so I was wonder if using the rift sawn board is also a no-no.
Thanks!
PostPosted: Thu Feb 02, 2017 4:40 pm
Last Name: Kincheloe
If it's smooth and flat, that should be ok. I taper to 3/4" at the 12th fret and 5/8" at the nut before gluing the scarf joint and heel block, but then carve a little thinner in the end.
I don't think there's anything wrong with using riftsawn neck wood. Especially Honduran mahogany, which has little difference between the radial and tangential expansion rates. Straightness of grain is what matters.
Users browsing this forum: TRein and 49 guests
